Hi everyone!
After clearing errors on my Accord VSAA light turn ON. Was looking for solution here but did not found, so maybe my experience will be valuable.
Here are the step-by-step instructions (its is said that both steps need to be done, even if only one system show an error):
Step 1 - ABS Light
Step 2 - VSA Light
Step 1 - ABS Light
- Jump pin 4 and pin 9 (1 is on the fat side or top side, see attached picture)
- Hold brake pedal
- Turn ignition to ON (3rd position)
- ABS icon appears, after it off - let go brake pedal
- ABS appears again, press brake pedal till off
- ABS blinks twice
Step 2 - VSA Light
- Connect pin 9 to ground
- Turn ignition to ON (3rd position) (do not touch brake pedal)
- Once ABS icon OFF, press VSA button once
- ABS comes ON
- Press VSA again
