AC compressor
venoox
Accord 2.2 i-DTEC
Hi everyone,
I’m looking for a replacement AC compressor for my 2009 Honda Accord Tourer 2.2 i-DTEC (N22B1). I was initially searching for a new Denso compressor specifically for the Accord i-DTEC, but it seems like it’s no longer available, at least from the sources I checked. Because of the high cost of new OEM units, I’d prefer to buy a used one if possible.
Since finding an Accord i-DTEC compressor is proving difficult, I’m considering possible alternatives:
  1. Honda CR-V 2.2 i-DTEC – It appears to use the same Denso 10SR15C compressor, but it has a different part number. Does anyone know if this would fit?
  2. Honda Accord 2.2 i-CDTI – There are plenty of compressors from the older i-CDTI engine available, but from the pictures, they don’t seem identical. I ***ume they’re not compatible, but has anyone tried fitting one?
Since it's hard to find a used or new one, I'm also thinking about taking it to AC repair shop but I'm not sure if only the clutch is bad or the whole compressor seized.
I've just had same problem, finally sorted at Autodoc with an Airstal compressor £282, there are a few on ebay but they all seem different to mine. Did you get yours fixed?
I also bought the Airstal one from Autodoc and it's working fine (for now :D)
I should think that there's nothing wrong with the product and they have reimbursed me, so, apart from the inconvenience of fitting removing etc I wouldn't say anything other than I have been unlucky.
