Hi guys!
About a few months ago, when I turn-on the AC, I ear a weird noise that looks something knocking on something, not a metallic noise, almost like a bet hitting something. After a while the noise goes away and the AC seems to be working ok, at least it was making cold.
Today, I decided to look at the AC compressor with the AC turned-on. At first, I saw the AC compressor clutch engaging and the AC radiator fan turning-on as well as the weird noise. After a while, I was surprised that the fan turned-of and the clutch disengaged. I decided to let it working a few more minutes and it turned-on again, and after a while, it turned-off again...
I have been reading, and it seems the our Accord have pressure sensor, and when the pressure of the gas is too low, it turns off the AC to prevent any damage to the AC compressor.
Could the lack or low level of gas in the AC system explain the weird behaviour of the AC system?
Today, when I tested it, it was not too cold, about 16ÂșC. Any way, this is way lower temperature that we can set our AC. Could this explain why the AC compressor was turning on and off, since the temperature inside the car was probably higher than the temperature that the AC was set?
