AC runs when Recirculation off (temp set to HI)
StefaTGM
Honda Accord 2.2 '04
I got small issue with AC, even if its off (set to Manual) the ac compressor and radietor second fan start workig only when i disable Recirculation. Whatever if the temp is set to LOW or HI.
When i enable Recirculation the AC stops but my windows start fogging .
Is there some AC adaptarion i have to do?
By any chance have you swapped your factory headunit for an aftermarket one?
Nope, it's stock unit Sat Nav, but i do have a adapter comnected to it so i can connect my Phone over BT
Does it do the same thing when the engine is still warming up? (temperature gauge not rising yet)
When you turn on heating only when the engine is already hot, does the heating work immediately? (slow reaction could mean low coolant, blockage, or air in cooling system)
Do you get much heat out of your dash vents when you turn the heating on when the engine is still cold? (this is when the condenser bypass should be active)
I am asking all this to get an idea whether the condenser bypass is working properly. In the diesel cars the coolant water only slowly warms up, and cabin heating is boosted by electric heaters in the vents as well as by flowing hot compressed refrigerant through the cabin heat exchanger and dumping its heat there instead of in the the condenser in the front of the car, I am trying out work out if the recirculation setting is somehow activating the bypass.
I only became aware of this system this year, and I do not know the exact mechanism the cooling system uses to sense when the coolant is warm enough to deactivate the condenser bypass.
You could probably test if your problem has something to do with the bypass mechanism by temporarily disconnecting the wires to the bypass mechanism at the lower right (looking forward) side of the radiator, and see if the problem goes away. If it doen't, the problem is something else. I don't know if the default is open or shut though. I am ***uming the default is bypass = off.
Hey, thanks for clearing out this for me you might be on to something.
It does it when the engine is cold and will turn on even when it's set to off or Recirculation Off. What I noticed is that sometimes when the outside temp rises the AC will turn off and it won't turn on always only the fan will work (radiator second fan). I don't notice much difference in heat when AC is off or on it does take some time to heat up now in winter since temps are below 0.
Last year I cleaned the cabin radiator it was clogged up and it didn't blow hot air on both sides so that is fixed.
Do I have to take the bumper off to unplug the connector for the bypass valve? That's the one under the headlight?
The ***embly is bolted to the lower left side of the condenser if you are looking at it from the front. This is why the condenser for diesel cars is different from the petrol models - it has 2 holes on the underside that hold the bypass ***embly.
Bumper off is easiest, but you are only disconnecting the wires so try reach through the vents in the spoiler.
