Hello,
I have an Accord 2004 2.2 cdti. The problem is that sometimes it stalls (when idling for a few minutes, sometimes it stalls even when driving). But the biggest problem is that sometimes it does not start when cranking. Also after a while it started from first try (overnight), but now it does not. I have changed the battery, fuel pressure valve (which is on the passenger side), checked the injectors. I used ThinkDiag OBD2 tool to check for DTC's. It showed P1062 – Fuel rail pressure (FRP) sensor circuit high voltage after ignition on. I bought an aftermarket (Maxgear) FRP sensor and replaced with my old one, but it did not help and I got a DTC for fuel pressure valve (somehow), so I replaced back with my old OEM one (Bosch). To check what's going on I wanted to check what's the fuel pressure and I was surprised that my fuel rail pressure was ~122 MPA, when target is ~57MPA (FRP sensor voltage 3.28V) I can attach pics of it below. I disconnected the sensor and recorded data: Fuel rail pressure was 179.25 MPA and target was 29.17 MPA. (FRP sensor voltage 5.10V).
First pic is with connected sensor and second is with disconnected.
Also I need to mention that sometimes after the ride when I stop and am idling for a while, the battery indicator shows up in a dash for a few seconds and then disappears. Maybe my problem is related with wiring or alternator..
If anyone has any ideas or had similar situation, please share.
Thanks.
Thanks.
