And according to the schematic as you can see the circuit bypasses that BR - something that I call a terminator when you set it on LO. So... If you wanna feel the warmth on the passenger's sit without anyone sitting there try to switch the heating on LO and drive for a while (it's slow so it can take a while) should get warm. Let me know if I was right.
I do have a problem with my drivers sit heating - it doesn't work on HI. It works fine on LO. It's not a switch because it's been checked already, it's not a fuse and the relay because heating works on LO + heating on passenger's sit works perfectly on HI and LO. , it's not a broken heating mat as it works fine on LO so there is a continuity of the heating wire. The last two thing that I blame are thermostat (unlikely) and that "something" . Did anyone disassemble a heated sit down to heating mats? I wonder where the thermostat and that other thing is hidden and if it could be accessed without removing a leather from the sits (probably not)...
