Hi guys. hope you guys can help
so the other day we accidently tore the gasket from it. so no way i could get home. only way was to cut a gasket small enough to fit and squeeze it when bolting the regulator back on.
15 mins after i got home i smelt fuel so i knew where it was coming from.
Only to find out that when i took off the regulator for inspection, the gasket made a leak and a crack in it too!
so now i need a replacement.
However, i do hear how I could use a adjustable fuel pressure regulator (higher prices for better performance/start off )?? I am not sure whether i need the original fuel regulator to use this or just the adjustable regulator it self?
heres a pic just to make sure i dont confuse you guys
thanks for your help raelly appreciate being a Accord Type R Owner
