Accord Type S Performance Pads/ Discs
samlam34
london
accord 2.2 type s
any type s owners upgraded their discs and pads for performance stoppers.
I have used mtec discs with ebc pads
sent using tapatalk
Now checked a bit around and seems that VTTR make also a good kit for the Accord. 330mm front and 300mm rear BBK on stock calipers. Mounts, pads and discs for all around for cca 600€.
Jan Accord said:
RedStuff...
How do the red perform on road?
sent using tapatalk
From my experience are bad... Much worse that organic/OEM replacment pads with some grooved/drilled discs just to keep the braking surface of the pad clean.
This combo i have now ( MTEC brakes grooved and drilled discs and ATE organic pads ) are a beauty to have with severe driving conditions.
Just to give you an example: from 210km/h to 0 without any kind of problems or overheating.
Check for my setup in the 7 gen Modifying section. Hope it helps
