I don't know if you already have it fixed or not, but, it can be a sort of things, it can be the actuator/motor on your side that isnĀ“t working properly or it can be something related with the temperature sensor on your side also... but sometimes a refrigerant leak can cause that too, until you have none left and then both sides will fail to cool the air. And you should check the pollen filter too.
