Air Con
Cl7eire
Mk7 2.2
Well lads, I work at a place where the fix fridges and air con. I had them check the air con in my 2008 icdti because it doesn't blow super cold with air con on full wack.
He plugged in the tester machine and said there was no pressure drop with the ac on or off so recons it's a bad compressor, but he is waiting for his manager to come in to check what the low pressure switch should be. Is there anything else it to check or will I chuck on a new compressor from a breakers?
I have a basic reader at home, I'll plug it in later and see if anything comes up
