Your Honda spec wheels are 5x114.3 and the offset is 55mm
Those mazda wheels will fit but you will need spiggot rings as the centre bore size is larger than Honda.
The mazda wheels IIRC have a 52mm offset so will sit in the arches nicer and not cause any issue like rubbing.
I've just bought these and fingers crossed that they fit am over the moon with them! http://www.ebay.co.uk/itm/190634305...XX:IT&_trksid=p3984.m1436.l2649#ht_500wt_1287
http://www.ebay.co.uk/itm/New-set-67-1-64-1-Spigot-Rings-Reducing-Rings-Reducing-Collars-67-1-64-1-/250957238342?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&hash=item3a6e379046
Beware the plastic ones dont last long if your wheels come on and off a lot.
