Alternator issue?
dandreye
London
Accord 2L MT (CL7)
Hi All,
After jumpstarting my 2005 CL7 with a flat battery (the car has been left unattended for >3 months) the engine stalls right upon disconnecting the jumpstarter from the battery. I also tried leaving the jumpstarter connected and this way the engine stalls soon after on its own, apparently depleting the jumpstarter (it's a 16Ah/59Wh Gooloo ***an GP3000). After I give the latter some rest I can easily start the engine again with its help, so it seems the engine itself has no problems. Could it be anything else but dead alternator? It's first time I'm seeing this kind of issue.
I'm currently charging the battery to try it w/o the jumpstarter. Once the engine starts is it safe for all the electronics to disconnect the battery to see if it keeps running? Is it supposed to?
Many thanks in advance!
To test the alernator you need to measure the voltage in the system with the engine running. It should be putting out between 13.8 and 14.2 volts.
Yes, but the problem is: as soon as the jumpstarter is detached the engine stalls, so nothing to measure... I doubt I'll get the right reading if I measure it with the jumpstarter still attached to keep it running, or I will?
Measure the voltage before you start the engine, and with the engine running. You will get a good enough reading to see if the voltage of the alternator is too low, with the jumpstart battery attached.
(as long as the jumpstart "battery" is not a running car with a functioning alternator).
Will do: thank you. No it's a standalone jumpstarter here, not another car. In fact I no longer need it now that I have the battery fully charged.
Right, so with the fully charged battery the engine started and kept running fine w/o any jumpstarter and the charging voltage reading was stable at 14.5V, which I understand confirms that the alternator itself is fine (I measured it with the red probe at the alternator's positive contact and the "-" probe at the battery's "-". Unfortunately I forgot to measure it afterwards at both battery terminals to check the positive cabling in between). Could anyone please explain why it was previously stalling with the flat battery upon disconnecting the jumpstarter then? Shouldn't it keep running even with the battery detached once started?
The battery acts not only as a power source, but also as a stabiliser. When removed the alternator has nowhere to send the majority of the output and I would suspect the ECU shuts things down before expensive bits on the wiring loom get damaged through overvoltage.
Got it: thank you. And thanks to that ECU or whatever for preventing the damage any of those components then. It's the first time that the battery was completely flat as I left the car unattended for longer than usual. On several occasions in the past it was barely able to crank the engine but still managed to start it and everything was fine.
