Anti roll bar link change.
block
Worksop
56 Ex diesel saloon
Just had the car mot done and it failed. Guy said it had broke but reading the report it says only insecure. Is it a straightforward job to replace? More annoyed with the fact that after being diagnosed with a VSA modulator fault and asking the Honda garage where i get its mot done if it would fail because of this, they said no, even the mechanic said no, as it was a switchable driving aid. Its failed on this too now i have only ten days to get the vsa sorted! I wasnt 100% sure they were right at the time to be honest so i guess im to blame too!
Rant over.
Thanks for any help.
PS. As i now need a VSA modulator asap, can anyone remember the name of the companies that repair these parts? I think there is one localish to me up north. I need to get organised now! 10 day retest countdown has begun!
Rant over.
Might be able to help you here.....just had a v.similar problem mine!! Started out with a knocking from the underside of the car which kept triggering the VSA lights to come on and it would only reset when ignition turned off. Decided to change the anti-roll drop links back to genuine parts (broke one last year & fitted aftermarket ones - useless). Blade Honda in Cheltenham found source of problem (they could hear the knocking but couldn't pin-point it until both drop links were removed and the tension was released off the anti roll bar - problem turned out to be the two "D" bushes at a fiver each - car now nice n quiet AND NO problems with the VSA lights!!!! Might be worth a check!
Simon
Cheers Simon.
Defo the vsa is broke according to the dealer. And the light doesnt ever go off.
Thanks though.
