Are the Steering Wheel Controls Illuminated?
bockersjb
Chertsey
Accord 2.4 Exec
Just wondered and the steering wheel is very dark at night and surprised as the Cruise controls in particular are difficult to distinguish.
Mine are dark, no illumination at all. I ***ume a bulb or fuse has gone. Anyone know where i should start looking?
So after a LOT of forum searching it does appear they should be illuminated and the culprit is likely to be a connector loose in the back of the sound system.
This makes sense as the previous owner fitted an AUX USB interface, and it's a bad one! I'm now dithering about a Grom vs Xcarlink but when i do fit one of these I'll check all the plugs are seated properly, and get my upper display re-soldered.!
Pre 2005 cars are not illuminated.
Check the seatbelts, there is a label sewn on the bottom that gives date of production. Petrol cars spark plug leads if original usually have a date on them as well.
:( 10th Char in VIN is a 4 = 2004 build. That's annoying, the controls look like they are designed for back lighting too.
Thanks all for info
