Hi Steven, if its a cold reading on the min that’s absolutely fine as i've never known ATF to drop on a Honda unless there is problem or its been changed and not enough was put in it :blush: anyway don't be alarmed just make sure your parked on level ground when checking the level as the slightest incline will give no min or a max to overfilled reading.
