luvmyaccord
6th & Type R Mod
Valves should be adjusted only when the cylinder head temperature is less than 38°C (100°F), ideally the engine should be stone cold/left over night.
Adjust the Valve Clearances to:
Intake: 0.17 mm (0.007 in) ± 0.02 mm (0.0008 in)
Exhaust: 0.19 mm (0.007 in) ± 0.02 mm (0.0008 in)
Order should be cylinder 1 - 3 - 4 - 2
After adjusting, retorque the crankshaft pulley bolt to 245 Nm (25.0 kgf/m, 181 lbf/ft).
How to:
1. set engine to tdc, adjust valve's on number 1 cylinder
2.turn engine 180degrees anticlockwise,camshaft mark's pointing to exhaust side, adjust valves on number 3 cylinder
3.rotate engine 180 degrees, anticlockwise, camshaft mark's pointing down, adjust valve's on number 4 cylinder
4. rotate cylinder 180 degrees, camshaft mark's pointing to intake side, adjust valve's on number 2 cylinder
How to:
