Automatic gearbox problem
kamiljanikjoul
London
Executive 2.2ictdi
I bought recently honda accord 2.4 from 2007 with 100k miles .
I tested carefully before i bought it .
It drives ok but when i pressed acceleration pedal hardly down revs jumps to 5000 and looks like car dont accelerate . Looks like the gear is not in place or its on neutral.
Its happened to me 2 times already i was driving around 20miles per hour and pressed pedal really hard down.
Normal driving plus quite dynamic driving is ok.
Oil, filters , were replaced , there is a pink not smelly fluid in the gearbox .
Does anyone have similar problem ?
Any advices ?
Kamil
Clutch is slipping under load... To be sure- keep about 30mph/4th gear, push accelerator sharp/full and you will see the same effect...
I tried to do it on 4th gear , i can guess it was 4th , and its dit it too.
But it doesnt happenen all the time ,
Not sure why ...
Can i dridrive with this normally ?
Any clue what the repair cost ?
You really need to take it to a transmission specialist who can look at it.
We’ve not had any auto problems on here for the Accord.
You’ve done the obvious by changing the fluids etc.
My second question is did you get warranty with the car when you bought it? If you did you could maybe claim off that
Thank you for answer.
I did have warranty for 3 month but its just something basic like repairs up to 300 or 400 pounds.
What i notice is :
on auto mode when i pressed acceleration button fully down the clutch is slipping ,or looks like auto cant put right gear .
On semi auto ( i think thats how its called )
Car dont have this symptoms. On 2nd gear i pressed acceleration button fully down and its ok. Its weird
