Kuang
Had the Accord just over a week now and quite liking it
The pull to the right turned out to be the tyres, so a rotation and rebalance sorted that (although the wheel is still a few degrees off) but I've spotted something else in the last couple of days.
I've already mentioned the firm clutch and extremely low biting point, which everyone helpfully advised me was about par, but I've also noticed that first and second can be a bit notchy unless the pedal's completely buried in the carpet. Not a major problem, but I noticed that if I'm pulling away from standstill and using low revs, I'll often get an odd single cough/bark from the engine bay. There's no feeling of judder or shaking and it pulls away fine, just after making that sound. if I hold the revs a bit higher and feed in the clutch, it's ok. I've checked for slip and there's none of that either.
Just wondering if that's ringing bells with anyone?
Not sure if it's connected, but I've spotted that under load there's a slight rustle from behind the bulkhead - on a balanced throttle it goes, but you can hear it when you accelerate. It almost sounds like air blowing, but it's not an induction sound.
