MedicalFlyer
Hi all,
Over the next couple of months I'm planning of getting a good pile of bits together to fit to the car. I've had it since October and have happily stuck 5k miles on it (was 84.5k). Short of the starter motor giving up the ghost nothing else too exciting has happened yet. The car goes and stops just fine and has been very well cared for in its past life. But I don't like knowing things haven't been done for a while (cam belt is 7 years old with 18k on it for example).
My plan is to get all the belts, water pump, coolant, brake discs, pads and fluid done at the same time and then see about the transmission and power steering fluids at some point. I try to stick to using Blueprint parts where I can as they generally just work™.
Oil, plugs, leads and filters have all been done at least once so it's on to the bigger bits n pieces.
Basically by the end of the year/MOT time I want the car mechanically solid and then start on the beautification at some point.
Along with giving the brakes a good overhaul I was wondering if it would be worth fitting braided lines and if anyone here had done so and could recommend any particular places to get them.
I've seen these for £80ish for all four which seems reasonable:
http://auto.helperformance.com/honda-accord-cg9-2-0-vtec-1999-2003
They also seem to sell through Amazon and eBay with decent feedback
Here's a gratuitous shot of my chariot while it was clean for a change:
