Jan Accord
Hi guys [emoji2]
Today i was street racing with some guy and i had to push the brakes few times in extreme situation but something strange happened.
During braking the pedal started to drop, alomst to the floor but the brake effect did not drop the first time. The second braking after that happened the brake effect was way lower and the pedal too.
After a race i tryed with the car parked and the engine running, to pust the pedal hard and it drops almost to touch the floor.
With the engine off so no "brake booster" after one or two pumps the pedal is hard like rock and from the top when i push it realy hard it drops maybe one or two centimeters, so almost nothing.
The brake system is almost new ( check my brake thread ):
New brake master cylinder
New braided brakes lines
New discs drilled and slotted
New brake pads
New ABS sensors
New brake fluid ( yes is bleeded properly )
I had a similar symptom when i had the EBC RedStuff pads but after i changed them i didn't noticed that anymore until now.
To be honest i'm a bit afraid to drive it because i don't know what to expect even if i tryed the brakes again and the car stops but the pedal is not where it should be.
This brake system was already checked by two differend Honda services and both confirmed the perfect shape of it.
The MOT passed without problems
I realy don't know what could cause this problem so i really need your support.
Already made a little research and i found that the brake proportioning valve could cause this kind of sympromps... Opinion??
What do you suggest?
Thanks in advance
New brake pads
New ABS sensors
Thanks in advance
