Hi folks,
Wonder if you could help...this is probably because of a knackered bulb but thought I'd run it past you guys...I was randomly checking my rear lights last night and noticed that the left side rear tail light wasn't working (the one above the bumper corner, not the one in the boot)...looked at the bulb and it does look burnt out. While I was on I thought I'd better try the brake lights...lo and behold while the hight upper brake light below the rear screen works none of the other brake lights work...however when I put my lights on all of the corner and boot lights go on (apart from the knackered bulb of course). Could the lack of lower brake lights be a result of my single bulb being knackered ?cheers in advance !
