Dan2441
Hello all,
I'm a new member to this forum and new to the Honda Accord (well 2 weeks of owning one so far) [2007 2.2 i-CTDI Sport] and I'm from South Yorkshire.
I have found recently that when the car is stood still and I push the brake it will start to go to the floor. If I then pump the brake it will become stiff, but holding will depress it to the floor again.
When the engine is not running the brake is solid as a rock.
When driving and putting the anchors on harshly the car seems to stop well.
I've done some research, but many answers contradict others. Alot say it's the seals on the master cylinder and so there's a internal leak. However I stumbled across a forum post about a Toyota Corolla having a very similar problem and someone quoted straight from a service/handbook that cars equipped with ABS and EBD (Electronic brakeforce distribution) have brake pedals which will depress to the floor when the car is not moving and performance is not affected when moving. Infact the system will increase braking performance when the car is moving. With this EBD in mind I then did some searching with respect to the Honda Accord and found a couple of posts mentioning the VSA system somewhat includes EBD within it? So I tried turning the VSA off to see if the problem persists but it does.
Alarmed by the posts about master cylinder needing replacement I took my car to the Dealer I got it from and they checked the car and said it's fine and that the pedal is normal, they then took me to a Honda Civic to demonstrate, however in the Civic it wasn't as pronounced and he said because the Civic is newer and something about engine sizes can affect the power when idle, but stressed it doesn't affect braking when moving.
I'm still concerned however because of the said posts saying the cylinder needs replacing, so your inputs would be greatly appreciated.
Many thanks for reading my post and I look forward to your replies.
All the best,
Daniel
All the best,
Daniel
