joelonghair
- Messages
- 4
- Reaction score
- 0
- Car
- accord
Hi, I am looking to upgrade the front brakes on my Honda Accord.
It is a 2007 Asian market 2.4 currently fitted with original 280mm x 25mm brake discs and single piston Nissin CL17-C calipers.
I have read a couple of threads on here that detail possible upgrades but the threads were quite old so not sure if better options are available?
I was wondering whether the calipers from a 2008 CRV could work? They are twin piston and use 293mm disc, caliper model number 13CLT. From what I can tell the mounting holes are the same distance but slightly larger so some work is needed.
My other option is to use the calipers and discs from a Honda Inspire (JDM Accord). They use 300mmx28mm discs and 17CL16VN single piston calipers. I think the caliper is basically the same as what I have already so not sure if braking will be much improved?
Or any better options?
