Hi all.
After fitting subwoofer I turned my attention to the bluetooth/mp3 solution. My choice was Bury CC9058 kit with sot-047 adapter. This was my first time DIY and ended up with partial success. The problem is whenever I use A2DP/aux ,the sound is coming only through door speakers. I understand that the build-in amp converts HU signals from 4 channels into 8 channels output (high for tweeters, mid for door speakers , and low for 6x9 shelf speakers). Much for my disappointment there is no sound from tweeters and 6x9's when using aux/mp3 player , but when switching to stock HU (radio/cd) the sound is still as its suppose to be.
So I am looking for the solution how to make all the speakers play when using AUX/mp3.
The options are as far as I read :
- to feed tweeters from amp output for the front door speakers using hi level line converter- this mean to cut in somewhere into door speakers wires and connect converters, right? And the same for shelf 6x9 speakers -feeding them from rear door cables. My concern is whether the stock amp will be capable of handling rear door speakers plus shelf speakers off 2 channels now. What I mean fitting Bury kit causes 4 output(2 for tweeters and 2 for shelf) channels obsolete now, right?
- the other option might be replace stock amp with aftermarket one and run all the wiring from the scratch- which to be honest I want to avoid -I might be too challenging considering my lack of experience and no guidance available.
-last option is to give up and seek audio specialist help- any takers(Berkshire)?
And the last question- any way to use HU volume control for aux/mp3 (for now I have to turn off the HU in order to run Bury kit- otherwise I can hear both sources simultaneously)?
The whole idea behind it was to keep original HU, have bluetooth/mp3 and keep it simple- it is not anymore
