Calling all CU2 owners
civicric84
Oxford
Accord CU1
Hi,
As the ***le says I need some help from accord CU2 owners.
My dilemma: for some time now I have been considering upgrading the exhaust system on my CU1. I have thought about the custom made route but they are either to cheap and the workman ship isn't very good or they are too expensive. Then I thought about getting a CAT back system but there are hardly any options for the CU1. Unlike the CU2 there are quite a few options. So then I started thinking would an exhaust for a CU2 fit on to a CU1.
So for a while I have been asking various people if they knew the answer to this question. Many people haven't got a clue, some people have said no and only a few have said yes.
The only difference that I can see is that the CU1 doesn't have the exhaust hangers on the left hand side as it is a single tail pipe design. I have looked at pics online and exhaust diagrams and the shape, size and bends look the same. I then contacted Hond-r and they said it is a similar case to that of the 7th Gen CL7/CL9. Apparently the exhausts are the same but one lacks the exhaust hangers to mount the second back box.
So with this is in mind I came across a company called Bastuck (www.bastuck.de) who produce a dual exhaust system which they say fits both the CU1 and CU2. But for it to fit the CU1 they sell with the kit two mounting brackets to fit the 2nd (left hand) back box.
At the moment I am still waiting to hear back from them as to how these are mounted to the underside of the car ? Bolted or welded. Once I have the answer I plan on purchasing the Fujitsubo legalis-R for the CU2.
So finally my original question is would the CU2 owners on this forum be able to take pics of the exhaust hanger mounting points for the rear left back box and post them on here. So hen I know where to position them to fit the Fujitsubo exhaust.
Thanks in advance for your help.
Richard
Hi Richard I will have a look at mine when the rain stops.
I can see why this won't fit as lots of 7 gen diesels have had twin exhaust fitted.
Also there is a 8th gen diesel in bristol fitted with a twin setup.
Thanks Brett. Just need a couple of pics where the hangers are located on the chassis on the passenger side.
Bastuck got back to me and said the brackets they supply apparently bolt on to the chassis. Not sure this is true as haven't seen any holes in that location.
Any help us much appreciated.
Thanks for that. I already have those pics though. Just need someone with a CU2 to take pics of where the exhaust hangers are attached to chassis on rear left side. There should be 2 hangers.
I'm not sure they are the same. Has any one had the chance to look at the cu2 and take pics of the exhaust hanger?
