Hi Everyone
OK. got pipes off filter this evening and managed to pump fuel through filter right away so blockage up to filter output. also took pipe off the fuel pipe and fuel came out there too. so I know fuel is getting to the pump. the filter looks orginal. but cannot confirm 100% unless I get it off.
Got my Diagnostic checker too today so put that on after I done the filter check thing..
Here are the 4 fault codes I got....
P0087 = Fuel Rail/System Pressure - Too Low
P1065 = Unidentified code
P16A4 = Unidentified code
P0088 = Fuel Rail/System Pressure - Too High
Anyone got any suggestions as for what I might need to do next..
Pumped priming pump loads to get it hard but it did go hard after about 5 pumps as fuel already present....
Cheers Gary
Cheers Gary
