Hey Jon, Sorry I havent got back to you, I have had a nightmare with this, I bought this off eBay:
http://www.ebay.co.uk/itm/7-Piece-Diesel-Injector-Seat-Cutter-Cleaner-Tools-Set-Carbon-Remover-Kit-New-/130811415644?pt=LH_DefaultDomain_3&hash=item1e74f7cc5c
Gently without any force just rotated it, I lubricated it with IPA then, after all the carbon was free, I got my trusty Henry Hoover attached a straw to it with some brown tape, I sucked out the free carbon debris and then re-cleaned with IPA.
That was that, I bought a teng tools torque wrench and as I was reinserting the clamp bolt at 5Nm TORQUE the bolt snapped. Turns out that the Bolt had some corrosion on there at which it was already on its way out. I have now to take a recessed sheered bolt out of the head for the clamp bolt. I got the torque wrench tested and it is faulty, off by 21.5Nm I new it was fishy but I bought it new! bad luck on my part.
The other thing to be aware of are all those tiny components within the injectors. there is a tiny ball and cylinder that, if incorrectly replaced can damage the valve seal within the injector deeming it faulty. I encountered this on 1 injector.
I will have to get a new torx T-30 bolt for the clamp from somewhere and somehow remove this sheered bolt. the worst part of it is that it is recessed within the bore of the head, its almost impossible to get to.
Any suggestions?
Kindest Regards
Rob
I am stuck now without a car
