Goodluckmonkey
TA Friends
Putting an '09 N22A2 (inc. a fresh set of chains) in an '04 wagon shortly to commute to work in, and will be looking to have a stage 2 map for it.
I'm in a position where it'd be an ideal time to change a clutch too (as i'd also ideally not want to open it up in the next 100k)
If the dual-mass flywheel's showing significant wear, I'd also consider changing it.
Has anyone swapped to a single-mass flywheel? and has anyone had a DMF failure? (What hp output and mileage?)
Do I just go SMF and uprated clutch and forget about it?
Or do I go DMF and OE?
