CDTI engine in FRV coolant change
smokingman
Lincoln
Accord Tourer 2008/9
Morning all.
Contemplating changing the coolant in the CDTI powered FRV. One thing i am concerned about is the bleed screw on top of the engine, what are the chances of it snapping? Not sure of the history of coolant chance hence needs changing.
nokia
TA Friends
Enfield
8th Gen IDTEC Saloon
You can get away without using the bleed screw. Try loosening it gently by hand. If it doesn have it, leave it. Just leave the cap off for a good while and let it burp itself. Pour in the coolant slowly.
