Firstly thank you to you all for making me feel so welcome. I love boards as they can be better than any manual most of the time. Thanks for all the info on cleaning the valve I will see to it as soon as I get the car back from Honda. hopefully Monday. Pedro I see on other posts you have experience replacing the Lambda sensor. Is it easy or hard? I have the 1.8. I believe it is the same car as yourself. Again thanks for all the help guys.
Yeah, its quite easy, you just need to get a lambda sensor socket wrench to remove the old one and install the new one. You might me able to get it out with a regular spanner, but I would not risk it, it might be quite stuck.
This is the one that I bought: http://cgi.ebay.co.uk/Oxygen-lambda-sensor-removal-fitting-sockets-22mm-7-8-/390268540211?pt=UK_Hand_Tools_Equipment&hash=item5addd15533 I had to use the one with the biggest "arm", so I could fit the socket wrench in there. There is also this one, it seems pretty good: http://cgi.ebay.co.uk/22mm-Lambda-Oxygen-Sensor-22mm-Socket-Wrench-/360253875359?pt=UK_Hand_Tools_Equipment&hash=item53e0cde49f.
With this ones, you don't have the room to fit a wrench on top of it, so I don't recommend it. http://cgi.ebay.co.uk/New-Draper-55540-Lambda-Oxygen-Sensor-Socket-22mm-3-8-/150542400149?pt=UK_Hand_Tools_Equipment&hash=item230d06ba95
Yes, it is the same car, but yours might have two lambda sensors, if so, I guess that the most important is the one before the catalytic converter, between the engine and the catalytic converter. Mine only has one.
Also, if you buy the lambda sensor, make sure you go for a NGK-NTK, do not use the universal type or Bosch sensors, the car might not like them
h34r:
