Does anyone have a how to, or any tips about removing the CD cubby hole thing and the clock? I need to change the light on my clock, but can't find anything to undo/remove/move.
if you unscrew the gear knob with your hands then put your fingers in the gear gator at the back and pull up 9red arrows)working your way to the front yellow arrow.
now remove the ashtry and 12power socket by unscrewing the 4 screws marked
and then there is the cubby with the clock held in by the 4 gold screw, remove these and it will just lift out job done.
Yeah no worries mate. Won't be able to do it till wednesday as that's my next day off, but will happily do one.
Had a quick look while on my break and the only differnece between doing my ATR and the 6th gen accord will be that i need a spanner to remove my gear knob. But will defo post one when i've managed it.
Thanks TIN-MAN for the excellent write up. I did this job today as i wanted to install an external temp guage in the tray. Super instructions and a very easy job to do! ( routing the sensor through the front wing, however, was a right royal pain in the **** ! )
if you said i could of made your job a bit easier lol theres a gromet under the pedal box thats free to use its about 20mm dim and easy to get to from both sides
