Last year in December my clutch start to slip. So I’ve been to a Honda Shop and changed the clutch kit (clutch disk, pressure plate and bearing ). I’ve also told them to change the oil in the clutch pedal pomp, because it had a darkish color. After this operation the clutch did not slip anymore and clutch pedal was much softer. They told me the flywheel is OK and does not need to be replaced.
After driving it a while I’ve noticed that the disengagement course of the pedal is longer. The disengagement starts after I lifted a little my foot off the clutch pedal and it ends almost when I take the entire foot off the pedal. If I release my foot faster there is a feeling like the disengagement is done2 times. Has somebody or had this issue ?
And I have another issue that I had also before the clutch kit replacement. When changing from gear 1 to gear 2, after I release entirely my foot off the clutch pedal, I can hear and feel a click in the clutch pedal like something is engaging. This is reproducible only if I stop the engine and start it again. What could it be ?
I hope I’ve been clear enough.
Thanks.
Thanks.
