Hi All,
[ 2005 Accord Tourer iCTDi ]
I have recently started hearing a grinding noise when slightly pressing the clutch at the top of the pedal about 1 inch. Pressing the clutch further than this silences the noise. The clutch operation appears quite normal in terms of no slipping. The only other problem appears to be intermittent. Sometimes the clutch pedal feels like it doesn't spring back quick enough, but this is very intermittent.
I just gave it in to my local Honda dealer and they diagnosed this as a problem with the flywheel and release bearing and suggested I have both of these and the actual clutch replaces at quite a large cost (around £1700). The largest cost is apparently the flywheel part.
Just wonder if anyone else has experienced this type of problem or if the above sounds reasonable.
Thanks.
Thanks.
