Clutch Master Cylinder - Replacement? Same between Petrol / Diesel?
johnnytoxic
UK
Honda Accord
Struggling to find a replacement for an 8th Gen Accord Diesel.
These are the part numbers.
46925-TL0-E03
46925-TL0-E04
I've found this but this appears to be the Petrol part number.
46920-S7A-A03
What is confusing is these part websites do seem to list the Diesel car model being compatible with it.
Anyone know if there is in fact a difference between the Petrol and Diesel versions?
Jezzagt
Accord Mk8 2.2idtec
Hi. Did you ever get an answer?
I'm looking to buy a master cylinder and no-one appears to reference the correct part number.
Jezzagt
Accord Mk8 2.2idtec
The squeak is gone and the pedal feels great after a fluid change.
csak1981
Scotland
Accord Tourer 8th Ge
Awesome. Can you remember how did you get access to the top mounting nut as it's hidden behind alot off stuff. I can't even get my eyes on it there is so much in the way
Jezzagt
Accord Mk8 2.2idtec
It's not easy! I used a 1/4" ratchet with extensions. A universal joint and 12mm deep socket on the end. There's a hole in the plastic trim roughly in line above the nut. Fiddly as anything but worked for me.
