JAPIMPORT
Hi i have got more problems,today i was finding it hard to put the car in gear sometimes so decided to have a look at the clutch fork and slave cylinder to see if i could see anything,and i noticed that the clutch fork was loose and the piston on the slave cylinder was easy to push in and there was no pressure,so i had taken the slave cylinder of to inspect it closely,as i only replaced it a couple of weeks ago,it looked ok,i put it back on and bleed the brakes,and now the pedal stays on the floor no mater how many times i bleed it nothing changes,so i m thinking it must be the clutch master cylinder that has failed,im going mad now as ive just got the clutch done and now this,anyone have any ideas on what it could be
