That place where they auction things on the internet got it a while ago when things started to go wrong with the car. Just make sure the one you buy covers your model not many covered the diesel.
No, I have the detailed original spec on how to setup the clutch pedal and yes it was being held down by the switch and it was 13mm out of spec, but what I wanted to know was if the TSB had revised specs for pedal height, disengagement height, pedal travel, switch activation heights (there are two) free play. Its not just the switch acting as a pedal stop. Must say the clutch feels much better now (bites lower in the stroke) it is adjusted to Workshop Man Specs, despite looking odd, It sits higher than the brake pedal.
