Thanks everyone for replying it is much appreciated. I have replaced the ff twice once by a Honda dealer and then by other. It is still going on to safe mode when you reach 60mph. I have also had the fuel injectors tested, fuel rail sensors tested and one changed, the regulator on the high pressure fuel pump has been replaced by a new one, but we still have the same problem. The only thing that has not been changed is the fuel pump.........Help!!!!!!!!
what is this app called?Yup as above. I put it in my iPhone fault code program and nothing, so manufacturer specific. I'd suggest the fuel filter fix first. Use genuine only.
How handy are you with tools.
Just a thought but there a DIY's for both pre and post facelift fuel filters on here.
Has the car be RE-mapped and if so do you know by which company?
Has the code been reset and come back, or have you just read it from a scanner?
Maybe worth trying some BG244 to clean the fuel system, it is certainly cheaper than a fuel pump,
What mileage is the car?
