Hi. I thought I'd post the details of the problem I had recently and the fix. When starting the car I got nasty periodic grinding/knocking noise followed by some smoke from the drivers side of the engine bay. This noise then disappeared for a day before coming back with a vengance. This turned out to the crankshaft pulley (aka. harmonic balancer) that drives the aux belt. A new part is about £350 (only available from Honda) while a 2nd hand part is about £100. The new redesigned shorter aux belt was about £45.
The pulley has metal on the inside and outside with rubber sandwiched in between. The rubber disintegrated allowing metal bits to hit/grind off each other.
Apparently the Honda breakers yard said it was a common fault and they keep them on the shelf. There was some mention on this forum of it being a common problem in Poland but no-one from the UK seemed to know anything about it.
