Timberfake
my stereo section is at the top with the clock and cubby at the bottom but noticed on the service manual that the stereo is at the bottom so could they be swapped round?????
To get at the top double din you have to remove the control panel facia. There are three screws that hold it in above the clocks (speedo etc) remove those. Then gently pry out the 3 switches on the right (cruise control etc) and disconnect the plugs. BE AWARE there is a 4th retaining screw behind the centre plug. Finally pull out the hazard switch and disconnect then carefully pull the panel out (lower the steering wheel to lowest. Simples.
Be aware there is no cage in the bottom for a head unit but there is in the top. My plan was the same as your but I had to fit the double din in the top but it looks good.
