Hi Guys,
While my car was in with the Mech today having the rear caliper sorted, I asked him to check the alternator, as I was having starting problems despite having a new battery just before xmas.
Went to a local battery specialist for the battery.
Anyway turns out that the battery fitted had a cold cranking ampage of 400, way too low!
Cold cranking amperes (CCA) is the amount of current a battery can provide at 0 °F (−18 °C). The rating is defined as the current a lead-acid battery at that temperature can deliver for 30 seconds and maintain at least 1.2 volts per cell (7.2 volts for a 12-volt battery). It is a more demanding test than those at higher temperatures
My mech reckons min 600 needed, the parts dept at my local dealership didn't initially know what I was talking about but eventually called back to say I need 700.
Does anyone know the correct spec for a 2004 cdti?
Lesson on this one - not all batteries are equal, and replacing a battery too low a CCA will mean that starting problems persist!
Cheers Simon
Cheers Simon
