Jon_G
No Longer Active
Good job!
			Or a 2/3ft length of pipe on the end of the spanner?? and then pull, also there is a good bit of force needed. Chesjakspudowen said:thanks for this, changed the alternator on the weekend, the biggest challenge is access. And make sure you get the longest 14mm spanner you can! I managed by putting other spanner through the loop to give more leverage, but a big spanner would have made the job loads easier.
TheHole said:I have no idea why my thread wasnt made a sticky... But i made a tool to make changing the belt much easier:
http://typeaccord.co.uk/forum/topic/11712-7th-gen-new-aux-belt-alternator-diy/#entry131056
I thought it was? that is where I saw the Long spanner trick, and it helped me no end. So if it is not STICKY "MAKE IT SO" you mods "ENGAGE"
Thanksedgeoftime said:I have no idea why my thread wasnt made a sticky... But i made a tool to make changing the belt much easier:
 Jon_G said:@chesjak - the shorter belt mod only applies to pre-facelift diesel models... facelift models were manufactured with the shorter belt.
thanks for that as I was going to order itJon_G said:@chesjak - the shorter belt mod only applies to pre-facelift diesel models... facelift models were manufactured with the shorter belt.
It depends how much room there is as to the possible next stepsVasilis said:Pretensioner nut rounded off...any ideas please?
