hi all,
what are the service limits on a dmf ? i believe the limit on the spring ,however its measured, is 35mm . what else would require the change of flywheel? is it as a normal flywheel eg grooving ? i dont want to have to change it unless i have to. as i see it a dmf is only a damper to smooth out the clutch action.
thanks for your kind attention
brian
brian
