Double Din - Accord EX without SatNav
Kal
Yorkshire
Accord Exec 2004
Anybody got instructions on wiring a double din system on the back of the Premium Sound system (NON-Satnav) on the Accord EX?
I've looked around the forums, may have missed it so if you could point me to the link or supply instructions. that would be great.
I'm lookin at installing this double din kit from honda - http://www.hondaoriginalparts.com/honda_car_parts_selection.php?block_01=17SEA01&block_02=08B0601&block_03=2843
I've pulled out the OEM console under the premium sound system and can see a couple of ports on the back of the cd changer, i guess the port with no cables hanging out of it is the aux port, and the other is the main cabling from the stereo?
Can i simply get hold of a harness adaptor lead such as http://www.incar-emporium.com/product_info.php?products_id=4991&TeKnoID=60f33227070c3f213f392bd248f1d183
and piggy back the aftermarket double din off the OEM stereo?
Would i loose all functionality of the OEM stereo?
Any help will be appreciated
Kal
Hi bud I'm attempting a similar install, have not got to the wiring bit just yet bud,just waiting to find correct harness,from what iv found out,is that you you should be able to use the ac&everything else,although no sound will come from the oem unit(although it will be fully functional) you will need a 3 way adaptor,one end to go back into the oem unit(to power the ac controls)one end into the after market stereo,and one end into the loom its self,I'm still waiting to find the correct loom.
if you guys had premium sound systems then all you need is a parrot car it harness from auto leads and that's to plug into the cars amp and you have extra wiring ends for your new double din... that's what I have :)
i think i have the standard stereo jav bud(no cd changer or nothing)im guessing the premium sound system is the one with cd changer and all.
Yeah mines the 6 Cd chnager, J4JAv is it one of these that you have installed ?....http://www.dynamicsounds.co.uk/autoleads-sot071-parrot-lead-honda-accord-civic-p-2257.html
You know of any good links for finding the double din fascia ? - Only see this at Honda, but not cheap.
hi KAl , i got my double din facia from china...i can supply you with the link if your interested bud??
Hi guys, so anyone knows any links for double din facia and wire harness adapter? Thanks in advance
