Well after much thought i decided to convert my fog lights to drl running lights as i never use them and thought it would give the Accord a modern look.
Rather than buy a whole kit off ebay its easier to buy the bulbs and the relay as loose items and make ur own kit.
The relay gives you the option of drl off when normal lights on or go dim, i went with dim as it looks better i think. Also for the switched power source (ignition) i used the feed to the ecu, this is on a 20 sec timer after ignition is off to shut down the car, so the lights stay on for a short while.
Pictures/links below of what i used and also some pictures showing the lights.
Bulbs
Relay
Bulbs
Relay
