Electric Widow Fault
J_VTEC
North East
Accord Type S
Hi all,
This morning my drivers side electric window wound down then jammed on the way back up. It then wound itself all the way down into the door and jammed there too. I eventually got it to wind up again by quickly grabbing the top edge of the glass as I operated the switch. Of course this would have to happen during a torrential downpour.....
Does anyone know:
1. If this is a common fault
2. What the remedy is
3. How much it's likely to cost me to fix?
Thanks in advance.
J
Try some silicone spray in the runners. This used to happen to mine once every 6 months or so. A quick squirt of silicone spray did the trick.
Dont use WD40.
