Hi,
I've noticed recently that when I turn on the ignition when the engine is either cold or has been turned off for say 10 minutes or longer, both radiater cooling fans are running.
Start the car and the fans switch off about 2 or 3 seconds.
After running the car till it has warmed up, if I switch off the engine and then turn the ignition back on the fans are running, this is without the engine over heating at all.
When fully warmed up the temperature gauge is below normal, between one third and half way.
No other symptoms or warning lights or messages.
Is this a problem or a potential one?
Cheers,
Ampers.
Cheers,
Ampers.
