Are we sure that its cast iron?
The photo's loaded previously re welding the manifold were completed by a MIG welder and I have not seem dissimilar or cast welding wire for MIG's?
Secondly my experience is that IF you try to weld cast iron using MIG/TIG/ARC it is VERY prone to cracking as the material is very brittle and does not appreciate localised temperature changes.
Welding cast iron is usually undertaken by heating the entire unit in an oven to red hot then removing it quickly, apply local oxy/acc torch and weld, once completed put casting back into furnace (switched off) and let it SLOWLY reduce in temperature.
Its why I guess cast iron is usually cast and machined but not welded.
I suspect that the manifold is some type of cast steel but have never touched one off a Honda, but you live and learn
