Fitting fog lights
graemeg
Belfast
Accord 2.0 SE Vtec
Hi All,
Looking for some pointers in getting my fog lights wired up, the electrical side I have no issues with, I would just need some help with getting the wiring from the engine bay into the cabin/dash to get to the switch.
Thanks in advance
G
There is one rubber ring on the firewall behind the engine a bound of cables are going through there. You have to break the rubber ring and push through the cable and the cable will drop down in the passenger foot well (pic 3). I took off the rubber ring now I have difficulties putting it back to that whit plastic ring. You can try it without doing that. Good luck!
Thanks for the info, I did get sorted. Just booked around the engine bay and found exactly what you described. Ran the wiring across the back of the dash to the switch.
Not as bad a job as I thought it would be, the biggest headache was getting the front bumper off
