Fog Light Misting
Kernowhonda
Cornwall
Accord DTEC ES GT
Has anybody had any problems with their fog lights misting on the inside of the lens on the Mk8?
I have been told this is a common problem, if so has anybody had them replaced under warranty?
I believe they should be a sealed unit so moister should not form inside them.
There very easly cracked by stones from driving.
Are you sure it's not craked ?
No cracks in the lens's but the inside lens is damp on both?
TBH i haven't heard this before.What i would do is turn the fogs on for say 30 min to see if they dry out.
Must be cracked or the seal has gone in some way. Also check the bulb and rubber boot are on properly at the back. The wheel arch liner unclips and you can get you hand in around the back, maybe best left as a summer job, unless you have a garage and a ramp.
Replacements are around £50 on ebay, so no need to pay £150 from honda, just search '8th gen accord front fog'.
Thanks for all your tips I'll have a look to see if the rubber boot is fitted correctly...........will have to wait for the wind and rain to stop!!!!
