I think if you remove the cover you'll see 4 screws holding the actual foglight in place. At least thats how it is on the diesel. I did try to remove my cover a while ago but the screw was that stiff it didn't work.
i had to remove all the clips and bolts and pull one side of the bumper slightly for better
access then just a case of putting a screwdriver in to remove and refit.
I know mate, they cost £10O+ from Honda, luckily there's a member here selling
A new oem one for much less!!! Have you tried online breakers? Or even give HH a ring?
